StrokinHarley
A while back I had a problem with my 4x4 not engaging and it ended up being a dry rotted line at the hub connection. Well with my luck I know have another. I have checked all the 4x4 vacuum lines and there good and they hold vacuum. The 4x4 light comes on and you can here the differential engage. I also noticed when you shift the switch to 4high the A/C switches to defrost however I have no vacuum leak so whats the deal? could it be a solenoid?
Any help would be greatly appreciated
