RandyH
On my truck, it appeared I lot my alternator, voltage across the batteries (still tied together)was about 12.1, no difference engine started or not. I took the alternator off and had it tested at a starter/alternator rebuild shop and it tested good. Put it back together, still no charging voltage.
I also diconnected the batteries from each other and charged them separately and one took a charge fine, the other appears to not be taking a charge and is staying around 10.8 volts meaning I probably have a bad cell.
Even if the battery is bad, why would the alternator not be putting out? Is there a fuseible link in the system that might be blown? If so, where?
Did the battery cell short and take out a fuse link?
Any thoughts?
Thanks.
Any thoughts?
Thanks.
