Aftermarket fuel filter install: who's done it and other questions.
FTG-05
North Alabama
I want to install an auxiliary fuel filter in my 6.0. Since I already have an extra fuel filter mount, I plan to put this kit together myself vs. buying a kit from Dieselsite etc.
Anyone know of a writeup that's already been done? I specifically want to know where to intercept the fuel (i.e. cut the fuel lines), what size fuel lines I have on my '06 6.0 and whether or not I need one of the fuel line disconnector tools. Any other info would be great.
Thanks,
Al
I want to say with confidence that the fuel line size going to the fuel pump is 5/16.
I mounted the Dahl 100 with Tbar's help right behind the transfer case.I have pics up somewhere in a recent thread.
The Dahl 100 kit from Dieselsite was the best way for us as it's one stop shopping with everything needed for our particular install.
FTG-05
North Alabama
Thanks! I checked with a micorometer and confirmed that the 6.0 lines are 5/16".
What filter element do you have in your Dahl unit?
Thanks for the help.
Al
FTG-05
North Alabama
And this 2 micron filter is located pre-pump? If so, do you use a vacuum gague to monitor filter performance or as aid to tell when it's starting to get clogged?
I'm planning dual 5 micron filters in parallel, but I'm a little worried about starving the pump with 5's.
I have mine prepump. I wouldn't worry about starvation,I have the 2 micron and the fuel psi went up 3-4 psi at the OEM fuel filter.;tu
No vacuum gauge,I'm going to change the filter cartridge every 10k miles whether it needs it or not.
Thread with pics.
Fire1
Certified Diesel Driver
I'm also running a 2 micron Dahl 100 pre-pump. I monitor the pressure at the factory filter and change around 10,000 mile or if the pressure drops. No problems. Been doing it for 2 years now.
i could see doing that in the 7.3L since theres only ONE fuel filter
(and as i understand it, not the best one out there).
but the 6.0 already is filtered TWICE
FTG-05
North Alabama
Thread with pics.
Thanks! Where did you intercept the OEM fuel lines? I also take it that since yours is a 7.3, you removed the screen in the fuel tank or is that a bad assumption?
Bushpilot, two isn't enough for me. I plan to five total when I'm done.
Thanks,
Al
FlorWhitfe
