Accelerator peddle question
Russ
Found On Russ' Drive
New Brighton PA
Please excuse my newbie question here. My new to me 97. The accelerator peddle has a "dead spot" when pushed to the floor. IF I floor board the peddle I get little response, but If I lift up a little on the peddle approx. 1/2" the truck shifts into a lower gear and accelerates. Is this a known problem? is there a fix? Something out of adjustment? Thanks Russ
93turbo_animal
Marengo,ohio
simple Russ just adjust you throtle cable ooohhh wait you don't have one of those anymore just kidin ya Russ thats a nice clean lookin truck
JOAT
I Found Nemo!
The West Coast
If it's a true TPS dead spot you'd get a CEL. Try the pedal adjustment from Baz's page as you found.
Another thing thats not always obvious, is at above about 2/3 throttle the Torque Converter Clutch will lock at low speeds, giving slower acceleration. Some PCM's you can stop this by hitting the OD button off.
Russ
New Brighton PA
Thanks Aric, I guess I had that coming. :sweet Now off to do some :burnit :thumbs
Big K
SDD.com Hacker/Admin
Dallas, Texas
PSDfreak said:
Thanks for the link...thats a pretty reasonable price next to the ford parts counter...
-Casey
Remember to select the 96-97 One!
It is $263.00 :eek: :eek: :eek:
cityworldford
