ac condenser
bears4x4
grease monkey
katy texas
ac condenser fins are bent up from previous owner, ac doesnt cool like it should, is it owrth trying to bend the fins back or just spend the 150 and get a new one???
bigrigr
Real trks hv 3 pdls
provo, utah
There is a tool you can buy that can straighten the fins, it's called a condenser comb. You see them all over, at the usual parts houses, snap-on trucks, etc. I would straighten before I bought new, as long as the tubing is still in good shape. Have you had the a/c serviced recently? Now days they can suck out all the freon,clean and measure it,and refill the system to make sure you have the right amount of freon. That and the fin comb would be where I would start. fwiw
bears4x4
grease monkey
katy texas
ive vac tested the sys and all is good, the pressures are good , its just the bent fins thanks
FlorWhitfe
