As far as I know you can. Just check with your dealer. Not sure on the price.![]()
NAPA sells it for $175.
you're going to need a pair of snap-ring pliers with long tips to change it.
WOW!!! The Firestone store told me that the clutch was an integral part of the compressor and did not come separately. They were estimating $800.00 to replace my compressor, plus $120.00 for a/c evacuate & recharge freon.
dealer 189 for the parts , you can buy the parts to do it, i called today to check, so whats the defining things that would say replace the ac clutch Assembly verses replacing the whole compressor
thoughts
clutch gaps are typically around .015-.020"
Feeler guages (thin metal strips with graduated measurement). Same thing you would use to adjust valve clearance or check a warped head or block. Keep inserting a larger guage until there is slight drag. No lube required for this type of insertion.![]()
