ABS Light
Dieselpwrdredneck
Addicted2Diesel
paris, Ohio
Abs light started as intermittant mainly in the rain or on a real bumpy road. Now its on all the time. Im not sure where to start to find the problem. Any suggestions??
Thanks
Neal
Thanks
Neal
I'd betcha the (1999) Vehicle Speed Sensor (VSS) has got'n tired & dirty*. It's located on the top of the rear Dif. 10mm nut, hold down clamp, 2 pin connector.. 15 minute fix.
* It's a magnetic sensor that picks up signals.. from the Ring Gear. Provides all kinds of needed speed/rpm data to the PCM. ABS being just one of the signals.
Picks up metal particals... over normal Wear,Time & Miles and gets weak.
You might also check the connections on the ABS module.. infront of the fuel pump, on inter side of the d-side frame rail ?
Stroked68
This is FORD Country
Eudora, KS
I replaced that sensor on my gf's 99 F250 gasser and that fixed the same prob. Easy fix. :sweet
dieseltech1
tampa fl
there is also 2 sensors on each front hub check to make sure the bearings are tight
FlorWhitfe
