note ABS light on - not rear sensor
HOTVET67
06 F350 LOADED
NORTH OF DETROIT MI.
Well I thought I might luck out on replacing the rear ABS sensor 39K miles.
It was the LH front sensor 2 Hrs labor and 60 for the sensor.
On the rear sensor , had to pry mine out , and had to sand the inside of the rusty housing to get the new one in without ripping the o-ring.
Just some info to think about , it's not always the easy rear sensor.
bomberman760
Kansas City, MO
I also have the mystery ABS light all the time. Thanks for that tidbit. Any difficulties replacing a front sensor in the driveway, or worth paying a shop?
HOTVET67
06 F350 LOADED
bomberman - I would pay the shop , unless you can trace which sensor it is , You also have to pull the brakes apart to get to the sensor .
4x4grey88
Nascar Fan #88
Kalifornia
Not really sure but I was told that if the ABS light comes on and it is not a brake issue (like the brakes are okay) that there is a problem with the charging system. When mine was staying on the alternator was going bad (low voltage) to battery.
gotogelsuper8461
