A pillar removal
TexasExcursion
GOD Bless America!
West Point, NY
Norcal250 said:
is there any tricks to taking an A pillar off? don't want to break anything.. thanks
I assume you're talking about the molding?
If you've got the grab handle, remove the two covers and four screws. Remove the grab handle and pull the A-pillar cover off.
dboyw
Lancaster, PA
When I did mine, I started at the top, sorta dug fingers in between the headliner and pillar. Just pull gently and you should hear and fell the pop of the clips letter go.
CSIPSD
Bend, OR
Instructions: remove grab handle (if equiped) grab pillar, Pull hard. Sorry just in that kind of mood...
Norcal250
Gimp member
Castro Valley, CA
oops... sorry shoulda mentioned that... yes... and thanks for the info guys... :thumbs
SDEric
Here's my pride!
MD
SawZall! :D moolding should fall right off.
RoyBoy
Diesel Dork
central WI
Just had mine off last night, after the screws are out, if you pull off the rubber door strip, you can see the three steel clips. Pry gently directly on the clip, and they pop right off.:sweet
