A Little White Smoke...?
dpantazis
#12
under the cheddar curtain
check your oil for proper level.
look for signs of coolant contamination in the oil. when was the last time you changed the oil?
look for globs of oil in the overflow tank.
do this to rule out other stuff, its easy.
what is status of your batteries? 7.3 + chip + marginal voltage is no start.
really low oil => no start too.
does the tach move when your try to turn it over?
Contamination in the oil will make it look milky (water). Coolant that has oil will look spotty and have an oily feel to it.
