A few Questions
Scar13
Little elm, tx
1. When I shift into second its nice and hard, third I never feel, and 4th like a brick. Anyone else's third kinda soft and mushy? Automatic btw..
2. I ordered my chip from DP-tuner, Nice guy but does anyone know what a stock stright piped exhaust with the 80 hp will be on egt's?
ranger boy
Banned User
1. sounds fine to me :dunno
2. you'll probably be hitting 900-1100 a lot more than you ever would with a 4", i would definintely recommend a 4" turbo back exhaust (from anybody they're all the same pretty much, i do recommend MBRP)
Northeast Texas
turn the OD off and try it
3rd should be felt but not JOLTed, engage smooth with a little engagement slip, slight flare,
but if your hammering it it should be firm in all gears, with a bit of od Slip, then if continued you may be seeing BTS
mine was most of the time pretty sure and felt solid until od started to slip
BigRamrod
