a couple new pics of the stroke
94f450sd
certified nutjob
plymouth,ma
well i cut the running boards off of it,cleaned it a little,tightened up the grill and headlight trims.i dont care for the no runnin board look though.kinda makes it look like a dirty work truck more than a cruising play truck.i have the front rims that go to it.i gotta put springs in the front before i can put good tires on the aluminum wheels and put them back on it.
Hey, that looks just like a dirty ole work truck :lmao
Are the front wheels the same as the rears?
Should look real good Rich. :sweet
94f450sd
certified nutjob
plymouth,ma
the fender was like that when i bought it.i think a tire come off on the previos owner.it needs a nose anyways.and ya the front wheels are the same as the rear.it needs fron springs so its eatin tires like popcorn.so till its fixed im gonna run steel wheels so the aluminums dont get ruin by tire machines.
94f450sd
certified nutjob
plymouth,ma
spent the last couple days cleaning the interior and straightening up the wireing under the dash,mounting the low pressure oil pressure gauge.the carpet is junk but it looks 100% better than it did.the middle of the front and rear were black from grease and oil.plus there was candy and spilled juice from when i had kids all over the back seat,floor and door panels.and then 3 years or so of cigarette smoke on everything.that stuff is nasty!!!!i used purple power and water on it.i think it looks alot better than it did!!:D
Correy01
