Question A/C Not Working on 2001 F250 PSD
cpadolf3
US
I'll give it a shot. Thanks!
Sent from my SM-N910V using Tapatalk
cpadolf3
US
I'm at a total loss now... I've changed the resistor and checked every single fuse in the truck. I wouldn't think it's the switch because the AC was on and then suddenly stopped, without adjusting the switch at all. Any other ideas?
79jasper
El Paso, TX
Get a test light and see if the fan is getting power.
Or like Dave said, try straight battery power.
cpadolf3
US
I was originally confused on how to hook up the jumper wires. Just put them inside the wiring harness on the terminals or what? How do I know which is positive and negative?
It is a DC motor and it will spin backwards if you hook it up backwards. Don't be afraid of this, just hook one wire up and TOUCH the other one to the other battery terminal. It should jump and then spin. If not, the fan motor is shot. Good luck!
cpadolf3
US
Thank you very much!! I will try it tomorrow morning when I get to my shop
Tbar
SDD STAFF/Moderator
Can you feel air coming out of the defrost vents?
cpadolf3
US
No air at all.
cpadolf3
US
Nope. Nothing. I changed the resistor and today, pulled out the fan and hooked it to a 12v battery source. It ran just fine. Had it running in the truck, but seemed weak. I went to move my truck out of my shop and it wouldn't turn on again. Seems like a loose connection, but I've gone through everything and it all looks good
Jriltex
