99 lighting / electrical issues????sluggish???
vipertec
pa
my 99 super duty has had some electrical issues for the past few years that comes and goes. 1 is the feed to the headlight switch for parking la,ps and dash illum. goes out and found power at fuse in pdc but no power under dash where wire is coming thru firewall connector. Now last year I hooked up trailer wiring under pdc to rear of truck. I flipped over pdc and wired truck. After I returned pdc, truck cranked slow, no wait to start lamp, and of course no start. I messed around and tested power to ecm connector and found nothing. Shortly after, the truck started. Now , I know you will say it is the pdc that is bad, but under fuse panel showed power. Was wondering if anybody had issues with the firewall connectors doing this.( previous winter I lost power to accel. pedal also). Also want to ask again about a performance concern. my truck has new glow plugs, controller and starts fine when cold or warm but always smokes on start up. never uses any oil, but also seems to be under powered compared to two customer trucks I have, 1 being a 99 f450 dump and 2 a 2000 rollback with steel bed.They seem to have a lot more snot, and they both have high mileage like mine 182k. Not to bombard you with issues, just trying to resolve these issues before I give up and sell it for reliability concerns. thank you
Check the connectors that go through the firewall. A leaking windshield will cause corrosion at those connectors and cause this kind of problems. You can take apart the connectors and clean the terminals (with the batteries disconnected!) and reconnect using dielectric grease. Good Luck!
Dave ;tu
my guess would be Dave is close.
If you flipped the PDC over, and that's what "caused the problem" it would be logical to assume that the wiring to the PCM is loose, corroded, etc.
I think I'd start by doing what Dave said, then when I'm done, wiggle-pull-push-bend on the wiring loom and try to make it not work.
Chances are, the problem is right in that area.
