smokin joe
Smokin.....
You can do what you want but if your going to replace it, I would go to the ford garage and get the original equpiment and just replace it. If you start grinding and cutting on the fuel bowl (like you said you were going to do) you might run into problems. Replacing the heater is alot easier than replacing the bowl (if you screw it up). It looks like that one from "whatabudro" would fit right in without cutting or grinding. Just my 2 cents.
Randy
Randy
