KansasDiesel said:I better get out there with my meter and start checking wiring and that ac voltage as JOAT suggested
fyi..... thats VDC, and about roughly a hundred of them. Careful.
95_stroker said:fyi..... thats VDC, and about roughly a hundred of them. Careful.![]()
KansasDiesel said:Haven't had time to check the voltage but have disconnected the valve cover plugs the front 2 had oil in them??? Problem???
82FordTruck said:I ended up getting sent out of town today. Whoops.
Did you get anywhere? I should be back Friday, and will be in town Saturday all day mowing at work.
I am in agreement with the suggestion about the low pressure fuel side - I'd be curious to see how much fuel is coming out after the guage somewhere, as close to the injector as possible. Is it possible that thing is kinked, or the hose damaged internally while messing with the CPS? I am still struggling to make the connection here between the starting point and where we are now.
CPS controls timing of the injector, IDM tells it what to do, HPOP gives the injector juice, and the starter provides heat. I can't think of any reason that there would be no air at all.
Is there anything that could make it fire at the wrong time?
KD - I can't remember what you said. Did it die with a CEL and code thrown that you erased? Has it showed up at all since?
JOAT said:The CPS error may or may not be related to the truck quitting. Could have been an old stored code. Or whatever caused the original stall may have looked like a CPS failure to the PCM. Since it is the way the PCM knows the engine is turning, if the engines stops without the PCM knowing why, all it sees is a loss of CPS signal.
Can't think of anything other than maybe a high voltage short to the CPS wiring that would kill it.
Once you try cranking with a DCvoltmeter connected, we'll at least know if the IDM is trying to fire the injectors while cranking. Since we know it will buzz, the IDM seems OK. So could be a wiring problem to the CPS, or maybe a wiring issue causing a loss of voltage at the IDM, etc....
johndeerebones said:Buzz test checks that the solenoids are working and the computer is trying to fire them.
Check DC voltage at the valve cover connectors and make sure they are getting at least 100 volts...depends on which idm he has. if they arent you may have idm issues.
