06cumminspower
i have a budy with a super duty that has lost compression and found a powerstroke out of a 95, other than swapping injectors and turbo what issues could you run into to do the swap?
I'd also have to get a chip that will work with single shot programming.
I went through quite a bit of expense before I found someone who could get the tuning right for single shots in a Superduty. Save yourself the trouble and go straight to the solution: Bill @ Power Hungry Performance.
Bill put a modified single shot, stock tune on my PCM as well as single shot tunes on my flip chip.
