7.3 Powerstroke Diesel Down!
irish4x4
Mayor of Margaritaville
Reno, Nevada
We have a 2002 F-350 that crapped out in an intersection yesterday WITH a horse trailer hooked on. It appears to be something in the throttle/fuel system. Motor will start and idle but no response when skinny pedel is pushed, as if it were disconnected, and no guage activation. Guage fuse is intact???? Ideas?:censored:
Tbar
SDD STAFF/Moderator
TPS - Throttle Position Sensor. Its not unusual for these to go south.
Call one of our sponsors and order a new one. When it comes in R & R the skinny pedal.
Tbar
The Throttle Position Sensor went out on our 2002 as well,just required a stop at the dealer for the assembly:sweet
roosterdiesel
Earl needs B100
Amarillo,TX
Check your fuses. When installing my gauges I popped a fuse, don't remember which one. Truck would start but throttle pedal was dead.
irish4x4
Reno, Nevada
Well, our poor old 7.3 is back on the road. It was not the TPS. One of our drivers poped a fuse a few weeks ago (10 amp) and promptly replaced it with a 30 amp!!! It ran for a while then the fuse board, that is sandwiched, fin1ally started to meltdown. I traced the electrical problem to the "Tow/Haul" button on column. The two wires that lead to button had rubbed together so many times over the last 80,000 miles that the jackets were wore off and the two exposed wires had shorted against the steel frame work in the column and -POOF-!! Thanks to all for your help and input.:thanks
Big K
SDD.com Hacker/Admin
Dallas, Texas
WOW!!! :eek:
Well, at least ya got it running again :sweet
Wingdog
Thunder Bay, Ontario
And there's your proof not to put a larger fuse were it should not be. Or else other problems may arise. Glad you got her figured out.:cool:
