7.3 duel inlet mod
melmount
greensboro nc
so, do I have to do the one at the tank too? is it as important as the one at the pump? I saw the pick up deal. Isnt a disconnect on the outside of sending unit hooking to the gas line? hows that attach up there from factory?
No, you don't HAVE to do the in-tank mod*. The fuel pump inlet fitting mod is, IMO, more important to do.. because IF that fitting IS leaking air.. it IS leaking air in.. continuously.
*As long as you keep a half a tank of fuel on board.. the fitting in the tank is submerged in fuel and won't/can't suck air in.
AND.. for all that might be following this thread ? Don't Worry.. yer NOT going to Explode yer engine.. if you don't do these Mods.
But.. yer engine will probably run better, if you do them. Air, in the fuel supply lines, of a fuel injected engine.. Gas or Diesel, is not.. A Good Thing...?
melmount
greensboro nc
thanks big joe,
maybe i am missing it in your responses, what i am trying to ask is not about the inside the tank. The line where it hooks to the unit outside on top of the tank. is that a qd line?
does that leak air?(not referring to the pick up where you use a 3/8 coupler and a piece of line(ss)
sorry for all the questions and if I am missing it
thanks big joe,
No worries.
No, the exterior tank fittings are not QD type fittings
PM sent.
Wood County Tx
If yer refering to the Fuel Pump inlet mod.... Yul want to replace that Whole fitting assembly (plastic line, fitting, and 1 crimp clamp), that connects the steel line from the tank, to the inlet of the fuel pump.
There's specail tool available to release the QD type connector at the fuel pump... But, IMO, for the cost, and.. it's a One Time, Permentent fix... a pair of needle nose pliars or Vise Grips will do the job (yer call).
1. Pre-cut the diesel friendly fuel hose to needed length, put a band clamp on each end.
2. Remove the old fitting assembly, install the new hose... Be ready and be Quik.... fuel will dribble out.. from the tank.
3. Tighten the clamps. Cycle the key 2-3 times.. but don't start the engine.
Start the engine, check for leaks.. yer done.
Big Joe you get three gold stars
:clap:
best darn 10 bucks i ever spent on my 02,
waaaaaay back in the day :D
I love this stuff PB..;tu
OBTW ? Anyone thinking about doing this Mod ? Now would be a good time (and place) to install a pre-pump fuel filter. Many of the SDD vendor/sponcors have sweet kits.. with all the pieces, parts & hose, to do the deed.
:dunno
Sounds like you work for one of our sponsors Joe... :)
:lmao Nope :lmao
I just like to support them.. cuz they support SDD. Like the Header sez:
Please Support our advertisers, they help keep the lights on ! (?)
