bir7514
I gotta 00 f-250 that problems started happening by i would have to plug it in at 40degrees. But it would start fine. then it would start fine and then i would try to drive it and it would stall and barely move and had no power. The problems mainly went away when it was at running temp. After that i would have to turn it over for a long time and keep the fuel pedal floored to get it to start and it usually would stall alot after starting took a long time to keep it running. I know the glowplugs are out of it, but i dont know what else is wrong with it. I cleaned the air filter, changed the fuel filter, changed the oil, turned off my edge attitude..
any ideas???
any ideas???
