Question 6.0 Turbo Freewheelin??
RJDiesel
Waterbury CT
I have a 2005 6.0 and when I turn the truck off I can hear the turbo freewheelin, Is this normal? Hopefully this isn't a stupid question but this is the first diesel I have owned.:dunno
Trusted
DFW, Texas
yeah, The turbo is spinning at a fairly high rate of speed. When you turn the engine off, is takes a little while to stop it. Completely normal.
for sure.. when you stop hearing that noise... then be worried.. hopefully that doesn't happen :thumbs
X3 but... As with any Turbo Charged engine, when you pull in, to shut down (anywhere), It's good "Insurance" to let the the engine idle down for a few seconds.. or Minutes, after a work out.. to let the Turbo spool down and cool down to it's idle RPMs and lower the EGTs some.
I shut down after -300*, EGT... Bar None ?
Dogman
tampa,FL
300* I wish, I only can get to 400* wont go any lower then i shut down
bigrigr
Real trks hv 3 pdls
provo, utah
Mine will go to under 300, before I get tired of waiting. The pete will bury the gauge at 300, all the way down, in a couple of minutes. Maybe your not idling long ehough? Dunno.
The -300* is just My preference, on My 7.3. Maybe I shouldn't have put a # to it.. but the point I ment to make was: IMO, It's just not a good idea to just pull in and Shut'r Down, when it comes to the Turbo. Let'r Spool down, Cool down just a bit.
I'm sure there are folks that would say.. BS ! But I try to take care of my Stuff :lmao:lmao
X2 Big Joe!!
scottu5
