6.0 Tranny Cooler Upgrade on 7.3
Tbar
SDD STAFF/Moderator
Anyone have some good pictures of this mod?
Why are 90 degree fittings needed?
Tbar
aklim
Hartford, WI USA
The cooler has 2 barbs going towards the ground and your hoses run parallel to the ground so it might be easier. Also, you need to reduce the hose size from 1/2 to 3/8
Tbar
SDD STAFF/Moderator
dpantazis
#12
under the cheddar curtain
bolted right in.
lines out the bottom of the cooler are 1/2". lines from the tranny are 3/8"". i used the two barbed hose fittings to adapt sizes. connections to the 3/8" hardlines are jstu hose clamps. there should be some notes under the photos. ez-peezey, chicken and pie.
dpantazis
#12
its almost 3 times as big. look at the pics i linked.
