Euclid
Alright, this whole ordeal started out as what I thought to be a glow plug relay problem... I WISH!
The truck's an '03 F240 4x4 6.0 with a 6speed. The problem is that it takes a while to start up when it's been sitting a couple days and then it takes forever to warm up and it's seriously lacking in power.
I dropped it off at the dealership and $2500 later, after they said everything was fixed, I've still got the same problems.
Here's what they replaced:
oil pump
valve assembly
cam position sens
crank pos sens
engine bay wiring harness
nozzle assembly
reprogram/calibrate PCM
When I dropped it back off they told me that the PCM wasn't communicating with the injectors correctly and that was causing my problems. They quoted me $1027 for a PCM (yeah right...). They told me that I may also have an injectory problem.
Does anybody have any ideas as to what this problem might actually be? It could be the PCM, but I've lost all trust in this dealership. If it is the PCM, could anyone suggest a decent place to get a replacement as well as R&R how-to?
Thanks y'all, look forward to your tips/advice.
-Euclid
oil pump
valve assembly
cam position sens
crank pos sens
nozzle assembly
-Euclid
