6.0 changing fuel filters - any special instructions?
4x4grey88
Nascar Fan #88
Kalifornia
Is it required to replace both fuel filters at the same time? In my case it's probably a good idea as I am getting a CEL (with P2285) indicating a low fuel pressure to injectors. The manual also indicates to check the sensor for a short or loose wires.
Input???
snicklas
Super Moderator
Staff member
Greenfield, Indiana
I ALWAYS change BOTH filters at the same time (10K miles). They some as a set when I get them and the secondary is the easy one to get to (on the engine) and it is a smaller micron filter so the primary on the fraim rail catches all but the small stuff. I would try the filters first as they are alittle easier to do, and always good PM. Fuel system repairs on the 6.0 is extremely expensive, so I am more than happy to replace $45 in filters.......
