6.0 Carnage
Weweld
Fillmore Ca.
Yes we have the first 6.0 carnage from Stroked Lightning :sorry
The oil pump is 2 pieces normally 1 inner gear , 1 outer gear ;)
We have a highly modified oil pump it has 6 pieces :thumbs
1 outer gear and a 5 piece inner gear
The 5 piece inner gear is BROKEN :eek:
It also cracked the front engine cover and cut a few grooves in the oil pump cover and last but not least this will cause a no start problem that is very difficult to find.
Bummer Gene, going back in with like parts or are you going to do some more modding?:sly
Weweld
Fillmore Ca.
For right now we will be putting stock parts back in so we can make it to Houston after that we will look at a couple of different options, maybe upgraded pump parts or maybe even a dry sump system.
Invader
So now you mean "BROKED LIGHTNING". just joking sorry to hear that.
