4x4/air conditioning issue
JetDiesel04
Las vegas/Nevada
Sometimes when i engage my 4 wheel low range, my air conditioning cuts out and comes back on shortly there after... any ideas on a cause for this?
ckamp52
ckamp52
italy,tx and stephenville
my guess would be its because they both use the same vacuum pump so it is robbing the a/c for awhile during the 4x4 use...somebody will prolly be along shortly to give ya a better answer
X2 on what clamp52 said, but in the mean time......
You might check ther Vacuum lines that operate the front hubs.. fer leaks :dunno
T0MCHANDLER
Balaton MN (southwest MN)
I just think it would be cool to have this problem in December. AC is all natural in my neck of the woods this time of year. sounds like a vac issue. How long does it take to come back on?
JetDiesel04
Las vegas/Nevada
after i disengage the 4x4, it usually takes no more than a minute or two to come back on, i dont find myself using 4x4 too much living in vegas but the last 3 times i remember using it, this problem has occured.
bigrigr
Real trks hv 3 pdls
provo, utah
Sounds like a vacumn issue to me as well, maybe check the vacumn lines for kinks also.
scottu5
