Okay here is the best explanation i can give. I was driving with my passenger window down and i heard a sound like a chain was dragging along the ground. When i looked at my passenger front hub i found a steel ring that was clanking around on the ujoints of 4wd axle. I was able to push the piece of steel back into the back of the hub/axle area. Then i grabbed my axle at the ujoints area and tried to turn it but it was acting like it was locked, i double checked the hub and it was in the auto position.
i jacked up the tire and put a pry bar in the ujoints to hold it and turned the wheel and it popped and started to turn freely, but i can hear a small clicking noise as the wheel turns. Probably normal but thought i would mention that.
I then grabbed the ujoints to make sure the axle was free wheeling and that is when i noticed the whole assembly can move about an inch, i can shake it back and forth. It is tight going into the axle tube but very sloppy going into the hub, the drivers side does not move so i am pretty sure i have a problem just not sure what. Anybody have any ideas. i have never had one of these hubs apart. On my wifes 7.3 we lost a bearing and the whole front end almost fell off. can this happen with my 06 6.0 the wheel has no play top to bottom and spins nicely, it doesnt feel like it will fall off if i keep going until i can learn how to pull it apart. Any thoughts are appreciated.
