4R100 TC Lockup Mod Opinions?
SO.........let me get this straight, just to understand what ya'll are saying.
while your driving, you have to constantly flip this switch up and down when stopping and starting?
i dont have enuff brain memory to remember to do that.
if have the wrong idea bout this, please tell me.
Wood County Tx
YES, your right
and
the weak link with the 7.3 is the tranny and tc, i smoked mine real quick going up brindlee mountain two summers ago, the tc stayed locked right up to (programmer had it programmed to stay lcked to 30 mph)
SLIP GRAB SLIP GRAB SLIIIIIIIP GRAAAAAAAAA SLIIIIIIPPPPP
so we got a new truck :thumbs
CSIPSD
Bend, OR
Yes you have to flip the switch when starting and stoping... Thats why I went with a automatic type like SP diesels TC/Exhaust brake kit.
bears4x4
grease monkey
katy texas
lock up question
anybody have the progaming now that will do this for you automatically and where did you buy it????:thanks
HowieE
Princeton NJ
I have used a BD Torq Lock on my Sub for at least 100,000 miles and it was the best thing I ever added to the truck. Even though the BD was not designed to work with my 1997 OB2 in automatic mode it was still great. I would set the TC to lock manually rather than rely on the Torq Loc to do it automatically. The Torq Loc would then control the converter and disengage the TC at any speed below 33 mph.
My question is does anyone know what is the limitation that precludes spdiesel control from being used on a 2004 trans?
Fire1
Certified Diesel Driver
I've the manual switch and an indicator lamp for TC lock up. I mostly use the switch when towing the TT in city areas. Works great. You'll know quickly if you forget to unlock when coming to a stop.:D
HowieE
Princeton NJ
I assume if you are using the TC Lock Up in the city you are using it in 3rd. gear.
I had often used mine, on the Sub, in areas that I could hold a steady speed below that which the TC would lock on it's own, country roads and long hill. In some case 2nd gear on steep hills holding a speed of 35 plus.
It is that level of use that I am looking for with the Excursion, 3rd gear and occasional.
The whole idea of Tow Haul with the engine screaming just drives me nuts. Tow Haul must have been designed for a gasser with no guts.
Fire1
Yep. Third gear but below a speed that the computer will allow for lock up. It is very nice, but I really don't use it often. I'm glad that I did the mod though.
gotogelsuper8461
