4R100 made it to 94k miles!!
I had mine done by Aamco and had it back in 4 days.
just sayin.. :tounge
Honestly,when it comes down to it,I believe in supporting the small family owned businesses like Bama Auto Movers,Brian from BTS,ITP,Bob Riley,etc before throwing money at big corporations that in many cases won't back up their product or services like our friends do ;tu
Aamco's are all independently owned/operated..
ONLY reason I had them do mine is because I have known the rebuilder there for 30 years, and they could turn it around quickly.
I had called BTS for a ship-it-to-the-door quote a month earlier..
I was kind of surprised he doesn't keep cores around.. and I couldn't be without the truck for a month...
Wood County Tx
my 02 made it 47K
then it got traded in on a 06 :sly
its almost time for it to go, are you on pins and needles yet :D
Racinghcr
Racinghcr
Greensburg,Indiana
My 2001 F-350 7.3 PSD has got 96 k on it ,and has pulled our 15,000 lb Designer (36 ft long) Fifthwheels annually from Indiana to the Fla Keys without a problem. My local Ford Dealer mechanic said it would last much longer (pulling) if I maintained it religiously, and added a larger capacity aluminum Trans Pan. The Hughes trans Pan has about 5 extra qts of tranny fluid. I think this is the key--STOP THE HEAT BUILD UP WHEN TOWING HEAVY LOADS! I also think a Qt of Lucas Trans Treatment helps when changing. I wonder if there's any significant heat resistance to be gained with Synthetic fluids? Is that available for the older trannys? Any one know? Also,are trans heat gauges difficult to install on older F-350s like my 2001? Any other tips on Transmission Preservation out there? Thanks!
Valvoline MaxLife ATV is full synthetic and Mercon/Mercon V compatible.
and no, the temp gauge is a fairly quick install..
the sender screws in an existing boss in the case right by the "neutral safety" (it's really called a transmission range sensor) switch.
Stephen, I hope you can get it up there. Bill is jumping up and down by now..LOL
Bill I sent you a PM.
Got it done at the last hour yesterday, Literally. :yahoo
Got a text from Bill this morning that it is loaded and on it's way to Lead Hill, AR
gotogelsuper8461
