4lo no go
Yoslick
NW Wisc
Friends 03 6.0 automatic with the switch on the dash for 4x4 wont go into low lock, tried neutral, in park etc, goes into high and 2wd fine but no low, any ideas???
Thanks
Slick!!
First thing I think of is a vacuum leak which will prevent the hubs to engage. Does he only have vent air coming out the windshield defroster vents?
The hub seals may not be drawing in due to one or more is damaged in some way.
I'm throwing things out there based on personal experience.
Yoslick
NW Wisc
Vacuums great, seems to be a problem with the transfercase itself..Maybe electrical/connections???
Slick!
if the xfer box is goin' into 4hi but not 4lo, i suspect its cause his foot
is NOT on the brake <which is required>.
Yoslick
NW Wisc
BINGO!!! We have a winner!!!! Hit the brake pedal and in it went!!!!:sweet
Slick!!
when they called it ESOF (electronic shift on the FLY) they
apparently for got to tell folks that didnt apply to 4lo ;)
if you think about how whats really goin' on it makes sense that
you DONT wanna accidently select LO range when your
travelin' down the road at 55mph.... :dizzy
Yoslick
NW Wisc
I understand that, pretty easy to flip a switch accidentally especially when 4 wheelin, glad my 96 has a big ol lever to grab!!:sly His answer was "I was always taught to let go of the break to relieve any binding casued by braking..." :doh:
Slick!!
Kleetus
Butler PA
Yeah, that's interesting too, because I thought you actually HAD to be moving, under 5 mph to get it to go into low...
Well it works, so wonderful!
I like my stick on the floor...
nope...gotta be stopped, foot on the brake & in neutral (or maybe park)
TacoCat
