Russ
Found On Russ' Drive
Anyoneknow how to take the cup holder/cubbie hole apart? I have some loose change floating around in a 97 CC that needs to be removed. I don;t see any screws or clips that would hold it together. Thanks. Russ
Ahhh... brute forcestroked 350 said:the trim peice around the console lid pops off, i tried doing it broke most ol the tabs that hold it down. then i used silicone to put it back together. hope this helps
MUDWHISTLE said:On that subjest anyone know where to getone of those seats or have one they want to sell, I cannot find one in the wreck yards.
40 20 40 Center Console Disassembly
The whole console is made up of 5 parts, the cup holder, accordion door, the storage area, the storage area door, and the "trim piece"
The first and hardest part to get off is the trim piece. There are 2 "keepers" on the front and 3 down each side, 2 in the back, but you need to only get the front and the sides off so you can get it up just enough to get the accordion door out to get the lost change out or what ever is stuck in there.
To get the "keepers" loose, use a screwdriver to pry the foam down so you can see under the trim piece. You can’t see real good but you can at least find the keepers. The way the keeper’s work is they are a half arrow, and they fit into a groove. The trick is to apply some back and upward force and release the half arrowhead. I found that using a 90 deg pick tool worked the best. A small 90-degree screwdriver may work.
You’re going to end up breaking a couple of the keepers when doing this. Just take some clear silicone and glue it back down and wrapped some tape around the whole thing until it dries.
