melton74959
Has anyone else had the problem of the hydraulic jack, that came with the 2006 F350 super duty trucks, leaking hydraulic fluid out the top of the jack?
I have never used the jack and it sits in the jack cradle behind the rear seat. The other day I was clean my truck when I noticed fluid on the rear floor board. After I started cleaning it up I found it to be hydraulic fluid. After further searching I found a puddle of hydraulic fluid laying under the hydraulic jack. Naturally, I checked the screw caps to ensure everything was tight and it was. It seems the fluid is seeping out the top extension part of the jack.
As the jack has never been used I would assume the bushing, stalled by the jack manufacture should be good.
2006 F350 Super Duty 4 x 4 6.0L with High Pressure Oil Pump new kit installed.
