4.30 gears/mileage
rynarnell
03 6.0 8.0lift on 38"s
alaska
Hey i have been doing a lot of freeway driving lately with 38" tires and the stock 3.73 gears. It drives fine but i was going to get 4.30 put in. Will my fuel milege increase or decrease??
Thanks
ryan
fordtrucker4life!
I work with waste
SE Michigan
I'm not sure since you have a 38's. If your truck was stock and you put 4.30 gears in you would loose mileage. What mileage are you getting currently? With 38" tires you should gain mileage, but I am totally not sure.
rynarnell
alaska
im not sure, i havent recalibrated the speedo yet. i know i need to. i definitley would like it to be better though
Maxtor
Redding
"Generally", if you are towing at your peak torque, 2000 rpm, you should get your best mileage. Example, at 2000 rpm "empty" in overdrive (6th) gear, my speedometer is at 71 mph. If I were to only use the truck to pull a 5er or trailer, then I would change my gear ratio so as to be at the legal speed limit while pulling and be at 2000 rpm.
In your situation, at 2000 rpm, 38 inch tires, 3.73 differential, a speed of 61.12 mph is obtained while in direct drive (not overdrive). That looks pretty good to me.
irish4x4
Mayor of Margaritaville
Reno, Nevada
Thanks
ryan
SInce you likely cruise at 1200 RPM-ish at 65 mph. bumping up your ratio will bring the engine closer to its stock power band (higher RPM = More fuel) to a point. So yes, your mileage will go down at highway speeds but, your "Stop and Go" (87% of all driving) will be like night and day better. With 4.11's you could effectivle split the difference.:sly
rynarnell
alaska
ya its around 1100-1200rpm at 65 mph. I have been having to drive an hour to work on the freeway so i want to get the best fuel milege i can get. what do you guys recommend 4.11 or 4.30?
Maxtor
Redding
If you do the math, 4.30 differential with 38 inch tires will act like a
3.73 differential with 33 inch tires.
If your roads are flat, and mostly freeway, and not pulling anything, then you are probably getting the best mileage now.
With 33" tires and 3.73 differential, at 70 mph, 2000 rpm, = 18.5 mpg.
Hope this helps.
rynarnell
alaska
thanks for the help Maxtor , i think ill stick with the 3.73 for now.
patrickc
Ontario, Canada
I run 4.56's in my truck with 38's and the rpms are the same as running 3.73's and stock tires. I noticed about a 1 mpg drop on the highway with the 38's and 4.56's compared to 38's and 3.73's. Where they help the most is in town or stop and go traffic since the truck doesn't have to work as hard to get rolling.
TacoCat
