350 higher than 250?
orion_134
Woodbridge, VA
I have the truck in sig and it squats hard in the front. My buddy just put a leveling kit on the front of his 03 350 and wants to give me his springs. Did an 03 350 sit higher in the front than a 99 250? He tells me there is a higher spring count, so logically it should.
Thanks gurus,
Jesse
patrickc
Ontario, Canada
The 03 F350 springs should bring the front end of your truck up and should make it sit level front to rear. Most of the F350's sit a little higher (front and rear) than the 250's. I believe the spring count (# of leaves) is the same but they do have a different spring rate. (lbs needed to compress)
FlorWhitfe
