2022 fog light
mark1
Illinois
Is the factory led fog light a simple plug and play in place of the halogen ones on a 2022 f450?
Wood County Tx
on my 2021 the led fog light module is quite large behind the bumper and the actual lense you see is just a tip of the ice berg as it where
Wood County Tx
Do you happen to have the part number for the module?
nope
i can snap a pic later when i go over to the truck.......XXXXXX i just went over to try to get a picture but the module is blocked by a bumper support bracket
it should be searchable on the ford parts website
i know there are issues going on some trucks if they are normal lighting systems versus the leds
my truck for example is all factory LED, headlights, tails and fogs
non led trucks may have different wiring connectors and programming in the brain modules
you may need to check with forscan to see if the module can be switched over for led
this is not gospel, just what i have seen at other sites regarding l halogens to LEDs
Ricksofla
