2017 Ford F250
Tracy Mangus
Colorado
If you have ever tried to pass some slow big rigs on a 2 lane road, just to hit the speed limiter and not get around them and have to brake and get back in the line, you will understand why speed limiters can be just as dangerous as not having them in place, the speed rating of a tire is designed for long duration's at speeds above 117 in most cased, ( almost all tires have a rating of at least 117 these days) a burst of speed above that for short term, Like passing a trunk, is not the intent of a speed rated tire.
snicklas
Super Moderator
Staff member
Greenfield, Indiana
If you are on a 2 lane road, which should be 55-60MPH limit at the most, and you need to break 100MPH to pass them, then you shouldn't be passing in the first place. If that truck is doing the posted limit, or a couple miles under, then you shouldn't be passing, since you are already going as fast as you should be. If they are doing 40-45 and you have to break 100MPH to pass and get back in line, you shouldn't be passing, as the oncoming traffic is to close. To pass properly, you should have enough room to pass safely, at the posted limit. Meaning, what you are passing should be going SIGNIFICANTLY under the posted limit. The "I just don't want to be behind this damn truck" is not a reason to pass if they are at the speed limit, and definitely not an excuse to push double the speed limit. If they are "in your way" running the posted speed limit, YOU are the problem, not them. I have lived in farm country all my life, and being behind something slower is just the way it is. No reason to put many lives in danger because you can not be patient........
snicklas
Super Moderator
Staff member
Greenfield, Indiana
silly guy, we have 2 lane roads with posted 75 MPH
2 lane roads, one lane in each direction? Or 2 lanes in the same direction with 2 more in the other?
Around here, if the road is a true 2 lane road, one lane in each direction
the maximum speed limit in my part of the country (Midwest/Indiana/Illinois) is 55. To have a higher limit, it will be a 4 lane divided highway, and those are 60. Our highest speed limit anywhere is 70, and that’s on the interstate outside of major metropolitan areas. So I am not silly I am only sharing information on the roads I drive on.
However, the passing rules are still the same, no matter what the speed limit is. If the limit is 75, then you should only pass if you can in a timely manner at the speed limit. If the limit is 75 and you have to break 100 to pass, you shouldn’t be passing anyway.
79jasper
El Paso, TX
Man, I always confuse them.
So is it amount of lanes each direction? Or total lanes? Lol
Sent from my SM-G892A using Tapatalk
troutwest66
6.0- The Dark Side!
Post Falls, Idaho
Our two lanes here in Idaho are usually 60-65 max. Typically too narrow or curvy to hammer around someone. They have put a lot of passing lanes in when roads are curvy. Only the interstate goes above 65 mph.
Sent from my Moto G (4) using Tapatalk
harrelljr99
Georgia
I see a couple things here.
First, why do you feel the need to go over 96mph? Are you taking it down the drag strip?
Second, the computer has software to track if someone's been in there with a tuner or anything like that. Could cause you some grief.
What an old lady.
harrelljr99
Georgia
I have to agree, In my opinion, a 8000+ lb .doesn't need to go more that 100mph. That is a lot of truck to get slowed back down if something bad happens. I've had mine there just a couple of times. If I want to go that fast, I'll just drive my P71..... it was built for that......
It’s not about going over 100mph it’s about how fast you get there
