wizkid
fummins
im replacing the hpop. i just took the old one off, it seemed to make a click sound when i rotated the gear and it had quite a bit of play side to side and in and out. and I also suspect the o ring that is on top (the one held down under the two bolt plate) It felt stiff and the metal clamp piece showed that it had been leaking ( not a perfect circle from o ring outline) looks like it was sneaking by for quite some time.
So this should be my problem.
