Help Needed 2003 6.0 died while driving/no start
pequot lakes,mn
ok so it turns out it was the fuel pressure control module... i assume thats the same as the injector control module? anyhow it was 800 bucks. now that its running again the "miss" that use to be only when it was cold is now there all the time untill you really feed the fuel to it. any clue what that might be? and what should i use for an additive to clean the injectors?
6.0PSD777
Mass
I would dump a bottle of Power Service's Diesel Kleen in it. The miss could be an injector
Zmann ARGH
AZ
mine had a miss when cold since I bought it a year ago then it migrated to all the time ,, I just had 2 injectors replaced ,, no more miss
no / low fuel and 6.0 injectors is bad mojo ,, ford can test this for you 100$ diagnostic
