2002 Horn Relay Location?
MykolG
Sierra Madre, CA
I have the horn of all horns [that you can still use on an Excursion]. It is nornally found on a hook and ladder fire truch. The stutter horn. It is so big I will have to mount it on the frame under the front passenger seat. The tank and compressor will also have to be mounted there too. Ya need it on a truck this big.
I'm just running with a single TS100 which does the job :sweet
Ford_Forgotton
I got mine hooked up last weekend too. Just used a scotchlok on the horn wire coming out of the fuse/relay box to trigger my solinoid.
4-chime "yankee horn" off ebay. 130psi of pressure, and if your in front of the truck, your ears will ring for 5 minutes!
Jriltex
