MrTailLight
hey all, my father in law has a 2000 3/4 ton excursion and the read breaks keep sticking and making the wheel assembly hot, by even just driving around the block.
we have replaced the master cylinder already. we did take apart the rear lines and they did blow through....however, the rear calipers are sticking, and holding the breaks in.
i would think it is odd that both the rear rubber lines, or both the calipers would go bad at the same time??
is it possible for the ABS box to be bad?
what else could be the possible problem.....?
