justinslagter
7.3 died on highway wont start ... put in cam sensor and still wont .. the glow plug light wont come on it will turn but not fire ... please help
Welcome to the site Justin, I would recommend checking the fuel heater. Unplug it (located on the side of the fuel filter cannister) and then check the fuse. If its burnt replace it and try to start the truck.
Do you have a chip on it. If so pull the chip off and it should run. I installed a ts chip on my truck and it did the same thing.
that 'feature' was an indicator of bad batteries or low voltage.
A shorted fuel heater did the same thing on one in my shop. I bet that is it.
