1999 Powerstroke Excessive Oil Consumption
roosterdiesel
Earl needs B100
Amarillo,TX
Well your compression #s are good, prolly not the injector o-rings since the fuel filters good, and I take it your turbo is not pumping oil out the seals and there are no visible external leaks.........only thing left I can think about is the oil cooler leaking into the coolant.
platinum01
Willis, TX
Well it sounds like you have enough to check out. Welcome to SDD.com glad to see that SDD is making it name know. Post often
Brad1103
