repomanatlanta
My 97 7.3 rollback at 188k has problem, left side not firing
The other day, I filled up $50 bucks then 10 miles later all was not good. The engine acted like it ran out of fuel, check engine light. Pulled off road, turned truck off looked oil ok, start truck was very rough to start. Then, was only able to go very slow back home, wouldnt over over 30 mph. Changed the fuel filter, changed the oil, took to ford they said it was possible injector, they said the left side is not firing per computer. How do I pull the injector and what do I do after, and how can I tell if one is bad?
Does anyone have injectors for our 7.3 are reasonable $$. 843-324-5157
Thought well the value cover is off change out the harness, injectors and glow plugs on the left side the 2, 4, 6, 8 side. Now, my truck running only gets like 8 mpg, very bad wish I could get 20 mpg
