bspan27801
I love those FORD's
Good morning, I have a 06 F350 6.0 auto 4x4 and I have had my first problem in 55K miles. This has been a great truck so far and I love it. I usally plug in my truck all the time when it is lower that 40deg. Sometimes you can't plug it in when your traveling. Anyway had some cold temps here and one night i didnt plug it in and had a very ruff start. Cranks and stalls. once i get it started it runs ruff very ruff like not on all cylinders for about 40 seconds and then it is fine. Other wise runs perfect. If i plug it in it starts right up. The cel i have is p0470 that came on yesturday while tring to start it cold. Exhaust pressure sensor malfunction.
i thought the glow plug unit might not be working, but when i talked to the service guy at ford he said he never has replaced a glow plug unit on any newer 6.0. He said i need an update on the programming and maybe a ficm unit? I am really nervous about the programming, right now I can get 18 to 20mpg on the hyway. (of corse that is driveing very carfully and not over 65)I have heard that the new programming can hurt your fuel mileage and power!!! I have not had any problems out of this truck except I had to replace the batteries this past summer. Other than that I have taken really good care of this truck. Oh yea, I did have an update to the comp in 07 when I had the drive buy wire light come on while traveling in Pa, and all I needed was an update. Maybe I have the new update? I dono?!?!
Oil changes every 5,000 with pure one filter, castrol techtion oil, changed fuel filters eveyother oil change. Trans I changed fluid at 35,000 and then dropped the pan w/filter at 50K, and romote filter 4 times. I just cleaned the EGR valve for the first time two days before the Cel light came on thinking that maybe that was why it wasn't starting cold. New batterys Innerstate megatron plus 1000cca. The other things is I still have the original brake pads and there still perfect in 55K. I bet I will get 100,000 on these pads. there just maybe at half pad now. Man I love my truck, Thanks for reading my rambling, Look forward to your input!!!!
