Update Successful
I had that particular upgrade on my 6.0 L 06 F250 back in the middle of summer. I was also a little worried about what I might come away with. Actually, I can't tell the difference. I did chat with the diesel tech at the dealership at length about it. From what he told me and what others have put on here, the upgrade basically tells the computer not to look at the exhaust back pressure sensor as International has determined that the 6.0 doesn't need it after all. This was an input into the variable geometry turbo system used on these trucks. The side benefit is now if you want to put in an EGT or tuner, you have a handy 1/8" NPT spot on the front left manifold which is easy to get to and you don't have to worry about getting shavings in the turbo bearings.
