Help Needed 05 F550 refuses to start
Vindicator
Montrose, CA/ Ontario, CA
Hi all, I just picked up an 05 F550 Lariat. It came with a regular metal key and it cranks, but it wont start. If I spray ether down the intake, she'll start for a sec then die. There are no codes. Is my problem a lack of a PATS key??? How can I tell if I need one or not? Any info is greatly appreciated!:doh:
iirc, there was no pats key on the f series until 08. excursions had them, but not trucks.
sounds to me like you arent getting fuel. filter's clean? open the water separator and see if you get fuel coming out when you turn the key on?
First off don't be spraying Ether into a 6.0, it could go Boom big time or you could get a Ether lock. I don't know about the keys, but I am sure someone here does.
NO Ether or it will bOOm
X3. #2 ULSC Detonates. Ether Explodes. Big Diff.
My Standard, Boring input would be: Check & Clean the Battery Cables & Connections. Each Batterys Condition Too, Vindicator.
Yes Joe we know it your (My Standard, Boring input would be: Check & Clean the Battery Cables & Connections. Each Batterys Condition Too, Vindicator.) [/B]But in real life how many people don't do it, so just keep reminding all of us. Thanks, at least we know you care.
:lmao Oh I will Doug, I will :lmao
Think'n Back... There's been a good number of Gremlins, that were thought to be "Big Buck"... "Take It To the Dealer"... fixes.... remedied by just Clean'n things up a touch.. and testing some Batts..
I'll stay with it ;tu :lmao
