fordman60
hey guys any chance losing cooolant from the degas cap only under load could be anything but head gaskets? i have removed the egr cooler so cant be that, oil cooler was changed about a year ago when ford did my hg under warranty.
last time i had same symptoms, losing coolant under load, but i had them install an ARP stud kit, so i am hoping this is not the case again!!!!!!!
if the oil cooler is plugged up, can it cause overpressurization of the cooling system?
i was using a Superchips Flash Paq, but i removed it when i started losing coolant again.
i have no steam/ white smoke from the tailpipe.
could it be an injector o ring leaking pressure into the cooling system? i belive the injectors are cooled by the coolant, are they not?
enough questions yet? lol get back to me asap please with any info
