04 axle
munchie
Bronxnard
What size axle is in the 1ton 04. I'm looking into buying some gears for it! thanks
mine has a sterling 10.25 or 10.5....you need to be a little more descriptive
in what you mean by "size"...
ok well in THAT case the 99-current has a 10.5"....god knows i was
just under mine (and relocated the tags) when i changed over to the
NEW 08 fin'd cover.
but as i understand it theres a diff. housing for the DRW...so again...
more info would be helpful.
atk
Moderator
simcoe, ontario, canada
yes he didn`t state wether it was a srw or drw, but all he needs to to is get code of the tag ....there is alot of info on that tag.
munchie
Bronxnard
Sorry, i was in a rush out the door! What i meant was what kinda rear end is in it? like dana 60 or what ever. Its a SRW also
bigtrxs
The drw have a dana 80 and the srw have a sterling.The dana 80 has a 10 bolt cover and the sterling has 12 bolts.The dana 80 also comes on some f450. Im still trying to find the part # for the aluminum diff. cover for the dana 80. Does any body know?:thanks
keanoknick
Big Stroker
Cowtown TEXAS
It's not a Dana 80, the 250's have a sterling 10.25 and the 350's have a sterling 10.50 both share the same housing just different ring gear size. On the front axle it is a Dana 60 or 50 depending on year.
Maybe the Dually's have a dana 80 in the rear, but SRW SuperDuties don't:sweet
TacoCat
