0231 trouble code
superduty10
Buckeye Arizona
Does anyone know what 0231 code means?
I looked it up and it says fuel pump secondary circuit low. Does this mean bad fuel pump, plugged fuel filter maybe?
Any help would be greatly appreciated Thank You!:dunno
atk
Moderator
simcoe, ontario, canada
what i came up with...no voltage present at the fuel pump monitor circuit when it has been commanded on for more then 1 second....
indicates open, short circuit,relay,inertia switch,or fuel pump....
so it could mean bad fuel pump, but i would check the relay and maybe fuses and check some of the wiring if you can first...hope this helps
superduty10
Buckeye Arizona
Do ypu think maybe it would have somthing to do with the kill switch connected to kill the fuel pump? Thanks for everyones help!
Good place to start. Check all of the connections for corrosion and tightness. If they are soldiered, re-soldier them carefully. Good Luck
TacoCat
