Tail_Gunner
CRJ & ERJ A&P Mech.
And yes I did replace the thermostat. The stat came from NAPA and has the Navistar part number stamped in it, so I'm sure it's correct and seems to be working properly.
Be aware of a possible issue here. IIRC the correct T-stat will be a Ford unit. Even though the engine was built by Navistar, I've heard it said several times the water pump was not, it is a Ford waterpump. If that is true, then a Navistar t-stat may not be right. I think I heard there was some difference in height between the two.
